Hi
I capture to DV using my canopus advc 50.
I cant hear a shit during capture but the finished files is ok.
any1?
Do you mean:no Audio during Preview in capturing?If so, try DVApp.It lets you hear audio during preview capturing- at least sort of:the audio is delayed!No joy at all.AFAIK that's normal with DV capturing.
Nope, no need to. I listen to the camera when I capture.
Hello. -
Any1 have canopus advc 50 and useing studi 8 ?
The problem is i dont hear anything while capture, but the finished file is ok.
Thanks -
You won't, that's quite normal for DV capture. Think about it, you don't have an audio connection to your computer, just a Firewire data stream that contains both video and audio. If you need to hear while capturing, plug a pair of headphones into the jack on the camera.....Originally Posted by VCD GURU
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 03:45 -
How to capture audio only
By bigbomber5 in forum EditingReplies: 2Last Post: 1st Sep 2010, 15:38 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 10:47 -
Old PC and want to capture TV audio, etc.
By cantthinkofanickname in forum Capturing and VCRReplies: 1Last Post: 21st May 2008, 14:33 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 13:46
