When you download any of the new full-screen quicktime trailer's they have a still picture above and below the playing video, and because of this I have been unable to extract the video that is playing between the still pictures.
I've tried just dropping it into Vegas 4, but only the still frame and sound show up, not the video (same thing happens in VDub). When I right click on the file in Vegas and select Properties and try changing the video from "Still 1" to "Video" it still won't work.
I can't export from quicktime because i am a "Future Pro Key" user, meaning I have a key in my registry that says I am a quicktime 7 pro user, and my attempts to register with a quicktime 6 pro key do not work.
The only option I have left is the TMPGEnc add-on, but i will probably still have the same problem with the still frame.
For an example, you can try the Lord of the Rings - The Two Towers trailer: http://progressive.stream.aol.com/newline/gl/newline/lordoftherings/TheTwoTowers-tlr_fs.zip
If you have any success please reply, thanks! I'm trying to turn it into a divx file then edit and use it for my menu's intro.
Results 1 to 9 of 9
i opened it in tmpgenc (with the mov plugin) and clipped the frame on the top and bottom and saved as huffyuv avi file ...
done -- you have your clip ...
i have done this before in vegas but like you said this one doesnt work ..
but tmpgenc comes through -
and btw -- set source range to 0- 11493 to avoid the last pic which is encoded in there
set tmpgenc to progressive and 1:1 source and output to 24fps and 1:1 -
Where is the option to cut out the top and bottom frames in tmpgenc?
When saving you File>Output to File>AVI file, right? I didn't see huffyuv as one of the saving formats. In addition, wouldn't no compression provide better results? -
I found the clip option, but i decided to go with uncompressed since i didn't have huffyub. I'll let you know how it turns out.
uncompressed results in a huge file (you would have to install huffyuv as an additional codec) , you could use DV , divx also ..
well, i plan on going from divx to mpeg-2 for dvd.
which leads me to my next problem, what am I doing to do about the 24fps to get it to work on a dvd-player.
also, the sound is out of sync. -
Originally Posted by brentd49
dont compress to divx then to mpeg2 - at least if you want to mantain some quality ..
as the for the 24fps ... you encode it at 24fps and apply puldown to the mpeg file ... -
The reason I was going to go to divx first is because i wanted to edit it in VDub (I wanted to add a logo). But maybe I could do that with premiere while it is still a quicktime movie.
I'm still having a problem with the audio out of sync. Eventually I'm going to convert the audio into AC3, but does it really matter if I put as 41 or 48 khz in tmpgenc. I don't think that is the problem anyway. Any idea?
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
BD Rebuilder Full Backup without trailer
By jonlar in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2011, 14:46 -
Quicktime Full Screen not working in Leopard?
By ehmjay in forum MacReplies: 8Last Post: 3rd Apr 2008, 10:54
