Hello,
I would like some advice on the best settings to use with CCE Basic, as the guide merely explains them, without saying what is to be preferred in different situations.
In the "AVI decoding" of the "Options" tab:
*Try decoding in YUV format
*Try decoding in 32-bit RGB format
Which of these should be checked, for best results when encoding an interlaced NTSC AVI video?
Also, for DVD-compliant NTSC MPEG-2, what values should I use for M and N/M?
Lastly, what packet size?
Any and all advice welcome, as always.
Thanks,
Tom.
Lastly, what packet size?). They will not affect your playback quality in any meaningful way.
Impossible to see the future is. The Dark Side clouds everything...
Basic Rendering Settings for DVD using Sony Vegas Pro 8
By JerryRecords in forum EditingReplies: 1Last Post: 2nd Aug 2009, 14:13 -
Basic web streaming settings for my website.
By thurnau in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jun 2009, 02:10 -
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23 -
AVI->MPEG2 (CCE Basic) encoding results in incorrect video length in pla
By binister in forum Video ConversionReplies: 8Last Post: 26th Feb 2008, 17:29
