I'm fairly new at capturing, so I'm not sure of the problem. I was capping fine with VirtualDub a few months ago, but I formatted my computer recently and now, when I try to cap something in VirtualDub, the frames are dropping like crazy. The thing is, I don't remember what settings I had previously. I'm running an Athlon Gig Thunderbird with 640mbs of RAM. Are there any preliminary settings I should check so that I can cap without dropping frames this bad? I installed the Huffyuv Codec because I think I had that on there before, but that didn't seem to help out the frame loss. Any suggestions?
Make sure you're actually USING the Huffy Codec and not capturing UNCOMPRESSED. =|
Use the VCDHelp.com Capture Guide for reference...
http://www.vcdhelp.com/capture.htm
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
System dropping frames because it's getting old?
By quanz in forum Capturing and VCRReplies: 16Last Post: 30th Nov 2009, 06:20 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 01:25 -
VirtualDub Dropping Frames when capturing VHS
By big_al_40 in forum Capturing and VCRReplies: 8Last Post: 4th Jun 2007, 15:57
