  1. I own a Panasonic E20 desktop DVD recorder and I'm interested in trying DVDlab.
    Does anyone know whether DVDlab will accept the VR files (704 x 576 PAL) created by the Panasonic?
    Many Thanks
  2. I think that it probably should, might want to check out the official DVD-Lab sight though at www.mediachance.com
  3. If you are referring to the VRO files that it writes to DVD-RAM discs, just change the extension on the file name from ".vro" to ".mpg".
    DVDLab will accept it as an asset.
  4. Member classfour's Avatar
    The Heartland, United States
    If you merely rename the vro file, the audio will be out of sync.
    I'd recommend opening the .vro file with MPEG2VCR, editing, then saving it to your hard drive; then opening (and de-muxing) with DVDLab; you can also demux with MPEG2VCR, it's faster.
