Tools used: TMPGEnc plus, FitCD and CCE 2.50
Firstly, CCE 2.50 won't even accept my avisynth scripts.. i've tried 3 different scripts and CCE keeps giving me erro: "Does not support framerat 740x56.." ... ?? Here's a sample of my script
LoadPlugin("C:\PATH\MPEG2DEC.dll")
mpeg2source("C:\PATH\XX.d2v")
SeparateFields()
SeparateFields()
BilinearResize(320,224,0,0,352,288).Weave()
AddBorders(16,16,16,16)
AssumeFPS(23.976, true)
ResampleAudio(44100)
The one time that CCE did accept a file, the video came out shifted to the right so as to cut off about 1/4 of the right side of the movie.. ??
adam, thanks for your help, as well... Can you advise more, if you're around?? thanks!
From what I can tell, NOBODY makes CCE work properly except the serious gurus.
I don't think its output is higher-quality, so I just use TMPGEnc.
Someone needs to write a frontend for CCE that does all this scripting for us.
- Gurm
P.S. My method? I just merge the SVCD's, load up the video and the NTSC DVD template in TMPGEnc, and let it run. Yeah, it takes HOURS AND HOURS. Oh well. -
yea, no kidding.. the time factor w/tmpgenc is a huge deterrent.. thanks anyway.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
