can anyone explain this error, concerning cinema craft encoder?
fexp_close()failed***could not close the file c:\movie\encoded_video_cce_ntsc.MPV
the handle is invalid
windows error code 0x6 6]
I am trying to convert to SVCD.
the file i am importing is divxmpg4 v3.
Iam using cce as i belive it is the best.
i also have another format to convert to SVCD it's called XVID.
If you can solve my above problem will this one be the same.
It also takes from 6 to 8 hours,i belive it should only take about 3-4
MANY THANX for your time
and remember
PLAY UP POMPEY
POMPEY PLAY UP
not sure (never heard of that ) but ask the CCE tech support -- they usually are pretty helpfull
Frustration with Toshiba D-VR7 - why?!?!
By ottawadave in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Mar 2012, 01:38 -
My Computer Project = frustration
By jollyjohn in forum ComputerReplies: 36Last Post: 31st Mar 2011, 11:17 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 14:54 -
Video Work frustration
By bja5150 in forum Video ConversionReplies: 3Last Post: 18th May 2008, 15:08 -
'jitter' frustration on DVD
By hondo2160 in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 21:16
