  1. Hello, I am not a newbie; however I have a newbie question. I downloaded the trail version of dvd workshop and am having a difficult time with 2 things.
    1: Most of the time the "insert chapter" button on the right of the preview window is greyed out. There was one time when i was able to add new chapters to the large real on the right, but I don't know why the insert chapter button is greyed out?
    2: I can't create motion menus. I have searched online with no luck. Do you create them in the menu step or edit step? Is there a big difference between the trial version and the retail version?
    Thanks everyone.... without people like you guys the world would not go around.
    Feb 2003
    Hamiton, NJ, USA
    1. It sounds like you are using already-encoded MPEG-2 files as your source video. In this case, you can only place chapter points on I-frames (complete frames). The "Locae I-frame" option, right below the "Insert Chapter" button is useful here.
    2. You create motion menus in the "Menu" step.
    To create a motion background, select the "Menu" proprties tab in the top, left section, then drag your background video source from the "Library Manager" onto your menu.
    To create a motion button, select the "Button" proprties tab, and then drag your motion button video source from the "Library Manager" onto your menu.
    Ulead has some tutorials on this:
    http://www.ulead.com/learning/dws.htm
    I don't think they are all that great, but they do get you started.
    Hope this helps.
    Cheers,
    . Fred Scheifele
    . http://www.Scheif.net
  3. Thanks, I'll give it a shot. Do you know if there is much of a difference between the trial version and the retail version?
    Feb 2003
    Hamiton, NJ, USA
    I used the trial briefly. I think the biggest difference you'll notice is that the duration of motion menus is limited to a maximum of five seconds in the trial. In the full version, there is no limit.
    Also, I think the trial is based on version 1.2, so you lose all of the features added in 1.3 (enumerated here: http://www.ulead.com/tech/dws/dws_ftp.htm)
    Cheers,
    . Fred Scheifele
