help im stuck i used the guide that i got here did everything i was supposed to do then i went to burn it with nero and it burned the movie upside down.......can anyone help me....thanks
yes it was in avi. it plays great on my pc, its just plays upside down when i burn it.
If you do not mind an extra conversion, let Virtual Dub Flip vertical filter turn your AVI version upside down. Burn the inverted video, and it should come out right side up. This shoud work until you can figure out which program is corrupting your burns.
Hello. -
i have that problem only with the movies that have xvid.must be doing something wrong when i convert it. thankyou for your help
You could try the fourcc changer. This changes the header of your file to tell your PC to decode the video with a different codec. Change both entries from xvid to divx and it may solve your problem. Try it on a copy of the movie if you are not fully confident with what you are doing. If it plays as a divx, re-encode and see if it comes out the right way up.Originally Posted by billy
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
