I used CCE to encode an mpeg2 from avi and I attempted to author it with both DVDA and Spruceup. About 15 minutes into the movie I received the following error in the movie. "Avisynth caught an access violation at 0x0d183247 attemting to write to 0x35f2e1c8."
I'm simply going to reencode because I manually adjusted some of the bitrates in CCE in between scans and I probably violated DVD specs. Nevertheless I though I would post what happened just in case anyone else had seen a similar problem and could offer some advice about what may have happened. Any comments or insight would be appreciated.
Thanks in advance,
VC
Results 1 to 1 of 1
This is so much fun!
Doing SUBTITLES in DVDA Studio 5.0
By rainoz in forum Authoring (DVD)Replies: 1Last Post: 5th Mar 2012, 00:50 -
ISO to test DVDA
By AlanHK in forum AudioReplies: 6Last Post: 27th Jul 2010, 15:29 -
vegas 9 and dvda (not supporting .mpg?)
By nowchinatown in forum Authoring (DVD)Replies: 15Last Post: 12th Mar 2009, 15:28 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 15th Jul 2007, 00:24 -
Can you author and play BLU RAY using SD MPEG2's?
By faramith in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 02:11
