  1. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I have a problem DVDX 2.2. When I go to file then select the longest IFO file it does not encode the whole movie. It only encodes a very small part of it. Would anyone have suggestions as to what I could be doing wrong?
    I am trying to create a VCD from a REGION 3 DVD.
    I have used DVD2SVCD in the past but some of my friends dvd players can not play SVCD's. I don't want to use EAZY VCD because that program does not do subtitles. I would appreciate any advice on this matter. Thanks in advance!
  2. Banned
    Nov 2002
    Pgh Area
    Budz,
    Have you used this program before, or are you just trying it for the first time? I don't want you to think I am asking you a dumb ? if I ask "Did you click on "Whole Movie" or whatever it says on the Output Settings page. It defaults to, I think, 10000 frames. I have it running in the other room, and by the click, it is something like 145000 frames, a 97 minute conversion.
    I like the prog. It is running at approx. 1/2 real time, ie, 55 minutes encoded, an hour 55 elapsed time, VCD, at 2000 kbps, will just fill 2 CD-Rs. I think the result is more than adequate, and it plays on my machine, no prob.
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    LOL@me!!!!!! Thanks for the tip gmatov!!!! I guess I should concentrate on one thing at a time. I been trying to fix a friends pc while I was trying to learn how to use DVDX 2.2. Thanks again!!
