i tried to convert The Bone Collector with DVDx 1.4, and i've got this problem :
i load the IFO-file in DVDx, and didn't change any settings, only converting to VCD.
The program is making 2 MPG-file's.
The first one is no problem, but when it's starting to make the second file, the program says :
"Sample not found or audio decoding error.
It happens sometimes at beginning or end of movie.
Select continue will fill audio buffer with blank, continue ?? "
What is going wrong ??
It's the second time i try to convert The bone-collector, and at the same position it fails.
All other movie's i've done, i had no problems at all.
Results 1 to 1 of 1
MPEG Streamclip: "Audio Decoding Error"
By addresstom in forum AudioReplies: 3Last Post: 30th Aug 2011, 10:12 -
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
Error while decoding stream #0.0
By brassplyer in forum Video ConversionReplies: 0Last Post: 26th Aug 2009, 05:04 -
decoding audio for mkv using m2ts file PIDS error dg index used
By davidc78au in forum DVD RippingReplies: 1Last Post: 9th Feb 2008, 22:28 -
MPEG-2 Decoding Error
By shorto in forum Newbie / General discussionsReplies: 7Last Post: 21st Aug 2007, 15:41
