With DVD-R media I find that it's not possible to create multi-sessions. Unlike CD-R media that can have files added later if there's enough space, DVD-R's seem to be a one time record situation. I am using Nero for recording to my DVD-R's. The software states that multi-session is a problem except with Windows XP. I use Windows 2000.
Any thoughts? Thanks.
my first thought is the use of the word "some" - you will have problems with "some" dvd-roms and "some" operating systems.
I would get a dvd-rw and try it out. worst case, it doesn't work, you wipe the disc and re-burn it.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I did a multisession DVD-R once. It read in my burner (Pioneer 104) but not in my dvd-rom drive (an old Sony 8x)....mind you, my sony doesn't read DVD-RW either so I would say that it would depend on the age of your ROM drive....
In short, you should be fine unless it is a disk you want to send to someone else. Worst case it will still be readable in your burner."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
Finalizing is necessary to read the disc on a SETTOP only
However, the only drive that reads a multisession surely, as bartman observes, is the one that wrote it!
multi session
By didikai in forum Off topicReplies: 0Last Post: 28th May 2010, 04:44 -
Best "Multi session" DVD Image ??
By Anurag in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2009, 00:22 -
Verbatim DVD-Rs won't multi-session, it always finalizes.
By Stealth3si in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 07:26 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
