  1. Member videocheez's Avatar
    Jan 2003
    I'm trying to merge two different avi's (CD-1 and CD-2) using nandub and I get the following error:
    I used virtualdub to check out the file info and the audio appears to be the same for both CD's
    CD1
    CD2
    I'm looking for suggestions as to how I can fix the audio so that I can merge the two avi's. Any help of guidance will be apreciated..
    Thanks in advance,
    VC
    This is so much fun!
    Apr 2002
    The State of Frustration
    I would use AviSynth and run this script:
    AVISource("d:capcap1.avi")+AVISource("d:capcap2.av i")
    Hello.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can extract a wav audio file from each, then reload the wav back into each avi using the "wav audio" command, save each avi using "direct stream copy" for audio and video, you should be able to append segments after that.
