Alright, this is a bit difficult to explain...
Imagine Sequence A, B, C, and D...
What I need to do, is play Sequence A, which then presents the user with a choice. After the choice, I will need to play sequences D-B-C, and return to A. If they choose something else, I would need to play sequences C-B-D, and return to A. and with a third choice, it should play B-D-C, and return to A.
Basically I need to be able to make an interactive choice, and have that choice play other sequences or chapters in a certain order.
Is this even possible with a VCD? If so, please enlighten me. I have thought about how I am going to do this and it's driving me crazy!![]()
Yes, you need to chain a number of playlists and selections together.
I suggest you read about how it generally works here: http://www.michaeltam.com and then try some simple projects with VCDEasy. Then, once you get a handle on it, you shouldn't have too much trouble making what you want.
If you have any specific questions once you've had a go, don't hesitate to post again! It's a little bit difficult (and meaningless) at the moment to give step by step instructions without you understanding a little bit on how those programs work.
Best of luck.
Regards.Michael Tam
w: Morsels of Evidence
Check this thread..
https://www.videohelp.com/forum/viewtopic.php?t=162764
(has some XML code to achive this using VCDEasy)
Going nuts trying to convert a video
By ehunter in forum Video ConversionReplies: 38Last Post: 19th Mar 2010, 09:50 -
DVD Burner going nuts?
By Immortal25 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2009, 09:32 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 08:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 08:26 -
computer going nuts
By jyeh74 in forum Newbie / General discussionsReplies: 33Last Post: 11th Jul 2008, 20:18
