I have downloaded the official "TMPGEnc MPEG2 plugin" from the funky Japanese site which I cannot read nor decipher anything. At any rate, as I understand it from the "Tools Section of this website, all I have to do is unzip the contents of "m2v_vfp-0.6.36.lzh" to the TMPGEnc folder and all is fine. There are no installation procedures or anything? No installation makes me wonder if TMPGEnc will even realize that it is there. Oh, don't know if this is significant but I am using:
TMPGEnc Version 2.512.52.161 Plus
Is this all I need to correctly convert my PAL MPEG2 43-minute episode TO NTSC MPEG2 with my audio synced up? I've attempted this about 6 times now and my audio is always about 10-20 seconds out-of-sync. Any
advice would be greatly appreciated. Thanks
You'll need to convert audio, as well, with BeSweet..
<-- Check the PAL to NTSC guide to the left here under 'CONVERT'..
Here's a couple of detailed threads.
https://www.videohelp.com/forum/viewtopic.php?t=158525&highlight=bin+cue
https://www.videohelp.com/forum/viewtopic.php?t=164104
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 28th Sep 2009, 00:05 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 16:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 19:26 -
NTSC mpeg2 to pal needed
By Caned_and_Able in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 22:13
