Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Guest
    After I am done editing a MPG2 in DVD Workshop (removed ads), is it possible to export the video to MPG2 without DVD Workshop re-encoding it? If yes how?
    Thanks a lot for your help!
  2. Yes.
    Check the DO NOT CONVERT COMPLIANT FILES box.
    Also - follow the steps outlined in the article entitled SMART RENDER IN DEPTH.
    The article is located here:
    http://www.matroxusers.com/mreviews.php?op=showcontent&id=6
    (Scroll down to the bottom of the page - click the drop-down list arrow and choose SMART RENDER IN DEPTH.)
    Jerry Jones
    http://www.jonesgroup.net
