  1. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Hey all -
    I know someone here can help - I've searched the Virtualdub forums and these forums, as well as the Virtualdub documentation, but I seem to be missing this info...
    I have several video clips that are 720x480, and I want to resize them all to the same resolution. I know I can do this when I encode them to mpeg2 for my dvd, but I'd rather leave them as avi files for the time being, as I'm going to be compositing them together and making an intro movie for a dvd, and I don't want to encode, composite, then reencode.
    Is there a way to set up a batch encode in Vdub, so I can just spend some time setting it up, then go to bed and let it chug away overnight?
    If someone could walk me through the process, I'd appreciate it.
    thanks.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    MO, US
    As I recall, the "save" dialog has a check box to add the file to a batch queue for later processing instead of running it right away. But I admit that it's been a while since I used VirtualDub for batch processing....
  3. Sterno is right.... hit F7 to save each clip after you set it up...then make sure the little box in the left is checked...after you do all the setup for all your clips... press F4 and run the batch.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    gentlemen -
    thank you, thank you, thank you.
    I'll give that a try tonight.
    - housepig
    Housepig Records
    out now:
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    gentlemen -
    works like a charm - it's running right now.
    thanks again... that's going to come in real handy...
    - housepig
    Housepig Records
    out now:
