Ok, I'm recording movies from satellite onto my pc using Power VCR II in mpeg2 format. Then I use tmpgenc version 2.54 to encode it and cut out the junk. Then I use DVD-Lab to burn to dvd. When I load the movie into DVD-Lab it ask to demux the audio and I let it.
Here's my problem...I've burned several DVD's and haven't checked them in my home dvd player. I checked them today and the audio is out of sync slightly with the lips..etc.
I've looked at the files after recording from Power VCR and can't tell anything is out there...I've looked after tmpgenc...nothing there and even looked at the raw files that DVD-Labs creates and can't really find the audio out...if so I can't tell it.
So, it must be on the burning process. Anyone got any suggestions?
Thanks!
Darkcyber
Results 1 to 1 of 1
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 18:17 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
