Hi all:
where I can find MPEG2 codec? I want to convert my video (720*480)into NTSC SVCD format by TMPGEnc, however it couldn't be opened, I think it's because I don't have MPEG2 code installed, I even can't play it.
thanks
ls
install windvd... it installs mpeg2 capability with it... so wmp will be able to open it. only downfall is that if you remove windvd, it will also remove it from wmp.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Do you mean you have a video file (MPEG-1/AVI) and want to convert it to MPEG-2/SVCD? If so you do not need a MPEG-2 Codec in order to encode to MPEG-2/SVCD in TMPGEnc. -
___________________
In fact , I encoded a family video into SVCD format by EMPGEnc, recently, I need to re-encod it into VCD format( I have deleted the original AVI file captured from DV. the only thing left is the encoded MPEG2 format file).
But I found out I can't open it by TMPGEnc anymore, It tells me "can't open or unsupported".
During this period, one of the component's trial version is expeired . I assume it MPEG2 codec.
I downloaded winDVD as told by some folks from this forum, but I still can't open and encode it into VCD format.
any suggestion?
thanks
ls
Sounds like you just need to re-download TMpegEnc to reenable the MPEG2 support (it expires every 30 days due to "trial" status).
TMPGEnc can encode to MPEG-1 and MPEG-2, but it cannot decode MPEG-2 (btw it can decode MPEG-1). WinDVD can play MPEG-2 files, but it is not an encoder.
What you need for converting from MPEG-2 to MPEG-1 is DVD2AVI (for decoding MPEG-2) and TMPGEnc (for encoding to MPEG-1). A detailed tutorial can be found here.
<font size=-1>[ This Message was edited by: CornelisJ on 2001-10-01 14:27:14 ]</font> -
email me for a codec
if your running XP be sure to tell me
I can do MPEG-2 to MPEG-1 with TMPGEnc - as long as I have good codec (not some DVD installed one)
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 00:35 -
proprietary codec used by Sharp for MPEG2
By ghostma in forum Software PlayingReplies: 17Last Post: 16th Nov 2011, 17:11 -
no sound on some movies when playing with ps3 and mpeg2 codec issue
By dhyane in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 09:18 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 03:05 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49
