If I copy playstation 2 games with nero express do i need a mod chip or is there any programme that will make copys that do not need a chip.I dont fancy opening up my ps 2 , 2 put a chip in it.
Please ONLY post video related stuff in the newbie/general forum. I'm moving this one.
quite simply YES you need a modchip to play backup ps2 games the original disks contain a region coding that cannot be copied by any cd/dvd recording program the modchip imputs this coding when a disk is played ( the modchip also performs other functions needed to play backup disks) however if you dont fancy fiddling inside your ps2 you can get a usb modchip that you just plug in to the front usb port of the ps2 however this method also requires an action replay 2 or gameshark 2 cartrage and an original game disk as a swap trick is used to make the backup play personally i recommend you get someone who knows what they are doing to fit an internal modchip like the dms3 as it will allow direct boot of backup without any swap tricks or cartrages these are tricky to fit hence why i suggested getting someone who knows what they are doing to fit it ... if its done wrong your ps2 could be damaged
No you DO NOT need a mod chip to play backups. All you need is to install the flip-top (no soldering or touching any wires) which is basically another top (case) and swap magic discs.
Search for flip-top to find out more info. -
if u go to google and search for copying ps2 games u will get more information
1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
The future of chip cooling.
By HotDamn! in forum ComputerReplies: 0Last Post: 11th Mar 2010, 03:00 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 16:49 -
How can I know what chip my DVD player has?
By kingfire in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Apr 2008, 07:45 -
Does the Toshiba HD-A2 have the Reon Chip or not?
By ofield1 in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2008, 08:20 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
