I get my SVCD file and multiplex it as a Video-CD and after it's done, I play the .mpg file and the audio and video doesn't match. When I used TMPGEnc and stuff a few months ago, it worked fine, but I've tried this with 10 SVCD files and they all have the audio a few seconds ahead or before the video.
KuraiGuest
I had the same problem a while ago i guess you reencoded the sound
try putting in a delay while you are reencoding the sound. -
if the sound is off only a tiny bit you can try this:
- demux the mpg
- reencoded the audio (only the audio) with tmpgenc
- remux the old video with the new audio
- run svcd2dvdmpg again.
yf
Matching up video & audio.
By Tybo727 in forum EditingReplies: 8Last Post: 2nd Mar 2012, 02:57 -
Audio not matching with video
By jh1017 in forum Video ConversionReplies: 24Last Post: 13th Aug 2007, 22:00 -
Mac OS X: matching audio with video in iMovie
By Jeikobu in forum MacReplies: 3Last Post: 22nd May 2007, 10:48 -
Matching different video clips/Zooming in on audio in Adobe Premiere
By PharmBoy in forum EditingReplies: 3Last Post: 20th May 2007, 15:42 -
Audio not matching video
By doby48 in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2007, 09:53
