When I try to Author VBR MPEG2 files created with Cinemacraft 2.5, I get a message saying that the bitrate is too high. I encoded these files with the following settings: min=300 avg=4500 max=7000. Why is Tmpgenc DVD saying that the bitrate is 9800?? Files encoded with CBR are fine.
I get the same error. I think that CCE writes the max bitrate header info incorrectly.
Does anyone know if there is a utility to correct it in the MPV file? -
I use CCE Basic and get the same error message. There is some explanation in the CCE users guide as to why they always write a max of 9800 regardless of the true max rate, which I don't fully understand. However, I just hit the ignore button and go. Works fine. I've probably done 40 to 50 DVDs thus far in this manner. Just an added click or 2.
wwaag -
I thought about ignoring it, but I want my DVDs to be 100% compliant (or as near as possible), has anyone had any problems with DVD playback encoding with CCE?
I've just been re-reading the CCE manual... quote: "During VBR operation, 9.8Mbps is always written to the sequence header regardless of the specified maximum bitrate". I think it would be safe to ignore... (and i'll RTFM next time
Well.. i was wrong, i ignored it, authored the DVD (on a RW luckily), and it refused to work, it played fine on the PC though. Looks like ill be sticking with tmpgenc for the time being...
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20
