  1. if my computer can handle it..
    if im running an application or game while DVD decrypter is running does anyone know if that will effect the output of the movie?
    like.. getting choppy at some parts? or anything ?
  2. i am always multi tasking when using decrypter, never had a problem yet.
    thingimijig.
  3. another question..
    do you think if i multitask while DVDshrink is doing something that it will affect the output?
    Bay State, USA
    It will not affect the output, however, it will take longer to finish; and depend on PC and OS you are using, your computer may even hang.
