can anyone explain this error
fexp_close()failed***could not close the file c:\movie\encoded_video_cce_ntsc.MPV
the handle is invalid
windows error code 0x6 6]
More info needed.
Looks like the file you are importing is MPV, is it?
Why are you using CCE?
What fromat to what format?
Spill your guts.Don't give in to DVD2ONE, that leads to the dark side. -
I am trying to convert to SVCD.
the file i am importing is divxmpg4 v3.
Iam using cce as i belive it is the best.
i also have another format to convert to SVCD it's called XVID.
If you can solve my above problem will this one be the same.
MANY THANX for your time
and remember
PLAY UP POMPEY
POMPEY PLAY UP
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 16:23 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 05:24 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
