Okay. Here is my situation. Trying to author a DVD from client footage. To this point all the footage supplied to me has been quicktime .mov files in sorenson 3 compression. My latest batch of footage is from what we can tell the same compression codec. It will work on my client's machine, but I get an error when trying to open it up in quick time: "couldn't open the file, because it is not a format quick time understands" I've had the client reburn me a copy, but still getting the same error. I've tried opening this file in premiere, aftereffects and media player, all with the same result. There is a possibility it could be encoded differently, but I am unable to confirm which codec is being used. Is there a way to analyze the .mov file to find out which codec it's using, or is there any way to force a program to read the file (i.e. changing file ext to .dat such as a VCD file can be played by Media Player)? Any help would be greatly appreciated. So far, the only thing I can think is to have the client re-encoding with a different codec, then having him burn yet another copy (which unfortunately could take weeks)?
Try using AVICodec, or GSpot in the TOOLS section. They should report what codec was used to encode the file.
Impossible to see the future is. The Dark Side clouds everything...
Trying to fix a .mov that was corrupted after using undelete software
By Elderain in forum Newbie / General discussionsReplies: 10Last Post: 11th Oct 2012, 12:47 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 00:51 -
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 12:11 -
looking for somebody able to fix mp4 and mov files
By octopus in forum Video ConversionReplies: 2Last Post: 22nd Nov 2009, 03:52 -
Is there an application to fix mov files
By crookedsmile in forum EditingReplies: 5Last Post: 27th Nov 2007, 04:48
