After Installing Cool Edit Pro on my PC, then restart, my pc wont recognize my DVR-A05. I Uninstalled Cool Edit, then still the same thing.
None of my authoring apps will recognize it, or in my control panel. What is going on.
Can anyone tell me how to fix this problem
What does your Device Manager say for your drives ? Did you check that the driver is still properly installed ?
Did the program affect/effect or change your ASPI layer and or drivers. Some programs do this, with or without your approval.
(;-{> Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
I had the same thing happen to me a month ago...If you are running XP, then look for a feature somewhere in your control panel called, "system restore" You can set your computer settings to a few days earlier.
Got a similar problem. A friend just bought a new Dell with a DVD+ burner. Device manager shows its installed properly. You can play anything in it also. But when you try to burn a disc, the computer doesnt recognize it has a dvd burner. Prassi and Nero wont do anything. When we called Dell they said its an issue with the software not the burner. But nothing recognizes it. I also uninstalled it from the device manger and it reinstalled itself but still no luck. Any suggestions??
Thanks Boxingjunkie -
Sorry that someone bought a DELL. Unplug the DVD drive from the IDE cable when system is off of course. Re-boot without the drive hooked up. Shut down, hook the IDE cable back-up to the drive. Turn system on and see what happens.
jdizzy40
Just out of curiosity would shutting down the computer>unplugging the power>press the power button to discharge the capacitor>plug back in>and power up do the same thing. I just wondered if you knew, similar to after you update firmware??
(;-{> Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
my pc wont recognize my sony handicam dcr-hc21
By J.Frost in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2009, 23:27 -
dvd fab wont recognize target burner drive
By lauraji in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 00:34 -
For some reason comp wont recognize all computers on University network
By ryangarfield in forum ComputerReplies: 19Last Post: 2nd Apr 2009, 00:29 -
convertx wont recognize avi
By brdhsby5 in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 17:01 -
comp wont recognize older cd's & dvds
By lawzfeehily in forum Software PlayingReplies: 6Last Post: 12th Sep 2007, 16:56
