Error - No double posts, you have posted this message before. To edit it click on the EDIT button on your post here!
i hadnt posted the message before... i was posting a reply on a topic that i had already posted replys too. is this somethin on the forum or a problem with the way i am browsing the forum???
Results 1 to 12 of 12
it can only happen if you have clicked post and directly use the back button...hmmm...maybe also if two exactly enters a post reply or post new topic form....but it should not happen so often.
do you get that often? -
i have gotten it with a few topics... i usually use the back button a lot when browseing.... so ive stopped doing that... but even if i refresh the topic and try to post a reply again it gives me the same message.
right now the post im havin problems with is in the dvd ripping forum and the topic is "smartripper."
i want to tell the person that the noaspi.bat file is in the smartripper directory, but it gives me the double post error every time i try. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
test -
Opera 5.10
now im in IE 6 cause i just tried in opera again and it would let me reply in the double post topic. -
ok, that just posted fine... must be somethin in opera??? any ideas on how to fix it cause i love that web browser?
ok, just emptied my cache in opera... testing.
ok, that worked... thanks for your help though.
<font size=-1>[ This Message was edited by: DiViNeLeFT on 2001-09-25 13:27:15 ]</font> -
So it does work some times and some not with opera? it would even be better if it never worked....i hate such "bugs"...
okey so it caches "a bit much"....i cant actually do much about that and I dont want to rewrite my double post system again...
yep... it just happens to show up every now and then... if i close the window, clear the cache, open it back up and try again it works fine.
now my question... think it is a bug in opera, vcd help forum, or just some weird thing with the combination of the two?
How do i make new posts?
By Nick12 in forum Newbie / General discussionsReplies: 12Last Post: 9th May 2011, 05:53 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
New posts
By samijubal in forum FeedbackReplies: 2Last Post: 31st Jan 2010, 13:21 -
First posts to end all first posts
By zoobie in forum Off topicReplies: 4Last Post: 24th Apr 2009, 13:54 -
New Posts
By neumannu47 in forum FeedbackReplies: 5Last Post: 17th Feb 2008, 20:44
