Results 1 to 9 of 9
    Sep 2001
    england
    hi guys, like i say this could be the most stupid question yet,but i am a total newbie so please bare with me.
    i have just encoded an avi to mpeg,using tmpegenc,burned it using ez cd creator 5 platinum,and all i can find on the disk are some empty folders, and a .dat file.
    my question is, will this play on a standalone dvd player,(phillips dvd622,which will be purchased soon) or do i need to do some more work on the file(which plays ok on wmp).
    sorry for the ignorance of the question, but we all have to start somewhere.
    help me obi-wan kenobi, your my only hope.
    regards
    semloh
  2. all I can tell you is try it. The structure seems okay to me.
    Sep 2001
    Portland, OR
    Depends on which format you chose - VCD or SVCD. The file and folder structures are a little different. It looks like you chose the VCD format.
    I agree, try it. If it works, great.
    One suggestion, use CDRWs. Mistakes with CDRs can create a bunch of coasters.
    Sep 2001
    england
    thanks guys
    tried it today having taken delivery of my new dvd player,but it doesn`t work,i tried a back up disk of a music album,that worked,a borrowed home-made vcd,that worked,the media discs are the same but my file would`nt work,its not the dvd player, so any idea what i should do next
    thanks
  5. I dumped creator and went nero. Creator is unforgiving when creating s/vcd.
    Sep 2001
    england
    hi guys
    i have also dumped creator and used winoncd, happy to say everthing went great,perfect picture, sound and playback,
    thanx gents for all your help and advice
    regards
    semloh
    May 2001
    Brazil
    AFAIK, EZCDCreator will only work if it´s a legit copy...
    Non-legitimate copies of the software will produce coasters like the ones you´re describing... I may be wrong, though...
    rgds
    EBaldino
  8. Mine was legit, straight from roxio pre-order. And after learning how much better svcd is, creator was history.
    Sep 2001
    england
    mine is a legit copy of creator, but still i was getting these problems
