How do I do this? Is there some software that can grab the audio out of this AVI and save it as an mp3 or wav, or something?
I think it's DivX 5... if that even exists.. it needs the DivX 5.0.3 codec to play is all I really know. There's no programs I have that can tell me what it truly is... either stream.
Sorry if this is really generic, and thanks for any help!
Use a program called g spot to view information about the file, its good. as for ripping the audio out, use virtualdub, both programs are free, run virtualdub, open file, if you want a wave file from the mp3 file, goto audio tab and choose full processing mode, conversion, then set your attributes, or leave as is, depends if you want to change from 41,000 to 48,000 or vice versa, i would choose internal conversion and high quality if your going from one frequency to another with v-dub, but then again, i use besweet to do the re sample as i think it uses anti-alias, which gives a better result, not sure about v-dub, i think i read it dosent use it.
Hope it helps, any other questions give a reply.
Hercules Man -
I always use Goldwave to extract a wav from avi's, it handles AC3 and MP3 sound. Just load the avi and save.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Urgent Help - Grabbing subtitle from MP4 or AVI file
By antinikhil in forum SubtitleReplies: 2Last Post: 8th Oct 2010, 16:14 -
VLC (or better?) for grabbing still shots
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jun 2010, 20:58 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 18:53 -
YouTube grabber not grabbing
By Tbag in forum ComputerReplies: 6Last Post: 4th Dec 2007, 07:22
