i am just wondering if i am using the right guide to convert svcds to dvd so that they can play on any dvd player !! i used this guide to do ***** ******** and it worked fine on my player but not on my mateS? any reason and can u tell me if im using correct guide >> https://www.videohelp.com/forum/userguides/154453.php thnx
I've never used that guide before but it appears to not make a file that is 100% DVD compliant. It seems as if the resolution of the film is still the same as an svcd. If you want to make a fully compliant DVD you should re encode the film using a standard DVD template in TPMG. I also would advise not asking how to encode a film that is still in the theatres. That is verboten on this board. No doubt someone is already reporting you to a moderator. Do yourself a favor and edit out the film's name in your post.
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 00:19 -
DVD Author Guide
By brvignesh in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 09:39 -
DVD Rip Guide
By brvignesh in forum DVD RippingReplies: 11Last Post: 5th Dec 2007, 09:18 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 20:55
