I am having trouble creating svcds from my vobs that were created with OSex. When I select ‘decode with quicktime’ it spits out about 10-15 Mbs and then stops and begins processing the audio. When I select ‘decode with mplayer’ it does basically the same thing, but at also displays an error:
‘Too many video packets in the buffer: (4096 in 8288607 bytes).Maybe you are playing a non-interleaved stream/file or the codec failed?’.
I have tried updating both ffmpegx and the components several times with no change. It would almost seem that the vobs are the problem, yet I can view them without errors in vlc. Has anyone else had this problem? What am I missing/doing wrong???
Thanks in advance,
gabrielm
AnonymousGuest
Problem: Video Black and White in Samsung MM-DG25, How to change video outp
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jan 2011, 11:11 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
VHS/ DVD Go-Video problem. Bad video, good audio
By Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 20:31 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38
