I have a ATI TV Wonder VE on XP using all the updated drivers etc. from there site. When i want to record a music video from cable TV and pick the quality i want it to record at when i pick DVD quality it says it will record in MPEG-1 352 x 240 8.00 M / bit a sec Audio 48.000 Khz, 16 bit, stereo.
That's not true DVD format?
Results 1 to 11 of 11
Yes, it is. Check here and scroll down to technical info: https://www.videohelp.com/dvdOriginally Posted by David9799"Art is making something out of nothing and selling it." - Frank Zappa
ok but that Video File Comparison chart says DVD format is MPEG-2 720x480 only thing there that is MPEG1 is VCD?
1/2 DVD is 352x480.Originally Posted by Bob W"Art is making something out of nothing and selling it." - Frank Zappa
I always get confused by DVD standards. I know 720x480 mpeg-2 and 352x480 (1/2 D) mpeg-2 are DVD compliant and should play in any set top (1/2 maybe only with 4:3 aspect ratio).
What you have isn't really VCD due to the bitrate and I personally wouldn't bet the farm on how compatible it will be on a variety of set tops. But I've seen folks say it's compliant with specs... Like I say, I get confused! Curious how well that one works for folks? -
Valid DVD formats:
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG1 (Same as the VCD Standard)"Art is making something out of nothing and selling it." - Frank Zappa -
Forgive one more really stupid question- but if it's compliant, that means it should play in all set tops- correct? So even if my set top doesn't play vcds- which it doesn't- if I used 352 x 240 MPEG1 with a bitrate of 1.856 and authored just as I do my 1/2D, it should play in any set top that my 1/2 D DVDs do. Is this correct?
(I know the quality will suffer and I'm effectively deinterlacing, but I just want to be sure compliant really means they would as compatible as a 720x480 mpeg2 would be.) -
Valid DVD formats:
I'm confused if all the above is valid DVD formats are all the above DVD quality? -
DVD quality and valid dvd resolutions are two different things ..
DVD quality is subjective -- there is no set difinition of quality on a dvd (some can be the real s*)
i think the term , as used by ati, is more a marketing description .. the format though is a valid resolution as others pointed out ..
there are other critera on what is either considered standard (required) dvd encoding/layout parameters or what is considered a defacto stand becuase its always done that way ...
standalone players to be called dvd players are supposed to be able to ALWAYS play every valid resolution and bitrate (on comercial disks) , but there are always exceptions .. -
Thanks- this was what I was wondering about.standalone players to be called dvd players are supposed to be able to ALWAYS play every valid resolution and bitrate (on comercial disks) , but there are always exceptions.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 03:09 -
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 21:08 -
Need Quality DVD Burning Software?
By BassJunkie in forum DVD RippingReplies: 2Last Post: 7th Jul 2009, 11:11 -
Help setting quality settings on mencoder converting videos on my website!
By funnyspo in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2009, 17:55
