Im not sure why this is happening, as I've been converting DV files to DivX with VDub for quite a while now, but all of a sudden it decided to not work.
I load up my Type 2 DV file into VDubMod, goto Compression->DivX 5.0.5 Codec, all that stuff.... then when I click on Save As, I get:
"Cannot Start Video Compression:
The source image format is not acceptable.
(error code -2)"
Ive done this before successfully, and I cant figure out what, If anything, has changed. Any ideas?
check the resolution of your input. DivX requires the vertical resolution to be a multiple of 4, and the horizontal to be a multiple of 8 or 16 (I can never remember which). You could always ensure it's a multiple of 16 if in doubt, which would cover either 4,8, and 16. Search the DivX site to be sure. You might also peek to ensure nothing is wrong with your DV codec. Open the file with AVICodec, or GSpot and ensure the codec is installed, and registered properly. You'll find both in the TOOLS section.
Impossible to see the future is. The Dark Side clouds everything... -
Youre right, I have cropped the video and absentmindedly forgotten to check that it was a multiple... thanks alot.
It's an odd requirement that wasn't necessary in MPEG-2. The price you pay for advancement I supose.
H264 in vdub giving me an error.
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2009, 09:23 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 08:42 -
VDub/Divx - How to setup Aspect Ratio
By neomaine in forum Video ConversionReplies: 7Last Post: 6th Feb 2008, 16:05 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Vdub Mod Error with VOB conversion
By Aaron1927 in forum DVD RippingReplies: 3Last Post: 9th Aug 2007, 12:05
