I found one other post with the similar problem and no resolution. Hopefully I can provide enough info for troubleshooting.
Sony TRV-27 DV capture via firewire card stops after 20 - 30 seconds. Capture software tape counter continues but the video monitor within the capture s/w freezes and the audio stops. I've used VideoStudio 7, Scenalyzer, Pixela (Sony s/w),.. still happens.
Specs:
1394 card came with Soyo Fire Dragon motherboard
Intel 1.6Ghz
1 Gb ram
2 x 40 Gb Ultra DMA 100 Hdd
Creative Soundblaster Live! audio
ATI 7500 Video Card - 2 monitors
I make sure the hdd is not fragmented and there's nothing else running. I've uploaded before with my older Sony analog camcorder and an ATI Vivo card. I replaced the ATI card, camcorder, and software and now I'm stuck.
Ideas appreciated.
Rich
I contacted Sony support and received some direction. Apparently Sony DV camcorders only support 4pin to 4pin firewire cables. Even though Belkin and others advertise Sony on their 4-6pin version, Sony doesn't use the extra pins (which are for power). I'm going to swap out the cable and give it a shot.
I'll post the result.
Rich -
Don't know whether this would make much of a difference. I am using a cable that came supplied with my firewire card on my sony camcorder and it works just fine. I will have to check the cable but it is unlikely they would have supplied me with a 4-pin cable.
Thanks for the help. There is a menu setting on the camcorder that says "DV Out". I set that to yes and still doesn't work. Capture stops after 10 seconds or so.
Rich
Capture from Sony DRV530, stops after 3-10 seconds
By tepeco in forum Capturing and VCRReplies: 0Last Post: 12th Feb 2010, 15:42 -
Sony capture probs
By DaveDLF in forum Capturing and VCRReplies: 13Last Post: 23rd Mar 2009, 20:20 -
Sony RDR-VX525 Capture Problem
By Aviator327 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 18th Apr 2008, 06:07 -
VCR capture/Sony MiniDv jack problem
By dADDo in forum Capturing and VCRReplies: 2Last Post: 5th Dec 2007, 16:44 -
Video stops after intro - is it a chapter-problem or just corrupted?
By offtherecord in forum Software PlayingReplies: 2Last Post: 21st Nov 2007, 09:38
