I use a Pinnacle PCTV card to capture directly to DV. (television shows)
But when I convert it to MPEG2 the audio/video is out of sync.![]()
What is causing this big problem?
A> My system?? (AMD 1700+ XP, 40gig-hd for windows and 120gig for capturing & editting both 7200rpm. 512MB DDR & 64MB Geforce2)
I use this system only for capturing and burning DVD's there is no other software (like games and stuff) installed.
B> I've got a bit of noise on my TV-signal. But that seems to be almost gone after I burned the DVD.
So my question is: "If I buy a AMD 2400+ XP, will that help much?".![]()
Results 1 to 1 of 1
***May the force be with you! Always...***
DV Capture Problem
By sailworkless in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd Sep 2011, 10:14 -
capture problem
By Mario09 in forum Capturing and VCRReplies: 2Last Post: 21st Jan 2011, 07:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Problem
By Driftking978 in forum Capturing and VCRReplies: 5Last Post: 28th Apr 2008, 17:44 -
Capture problem
By jjaha in forum Capturing and VCRReplies: 0Last Post: 9th Mar 2008, 15:08
