I think the heat is getting to my brain todayI can't seem to find the synch option to put in an offset value under the options tab. I am using 0.0.7d. Is it available in this version? Thanks
AnonymousGuest
The OPTIONS tab is dependent on the kind of video you're encoding. Only the choices appropriate to the program used to encode a particular flavor of video will display.
For example, if you choose MPEG-2 as your video format, the OPTIONS tab screen changes to those parameters used by the mpeg2enc program etc., and you'll see that the SYNC box is there on the right side.
from srt to sup + offset?
By lantis in forum SubtitleReplies: 2Last Post: 30th Dec 2011, 12:27 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Detect/Show Audio Offset in H.264 TS?
By Martin J. in forum DVB / IPTVReplies: 2Last Post: 28th Aug 2008, 20:52 -
How to record mms:// vod-movies with offset?
By streamsaver in forum Video Streaming DownloadingReplies: 0Last Post: 17th Jul 2008, 07:13 -
Audio Offset In Avi Conversion
By Scav2003 in forum MacReplies: 4Last Post: 4th Feb 2008, 13:26
