what is ms-mpeg v3 i downloaded a movie from the net and when i tryed to play it said invalid format. Which i thought was weird as i have codecs to run all my other avi movies. Can anyone recommaned a good codec for it.
Thanks alot
kilika
The decompressor is included in the Media player 7, though it's locked so you can't encode with it, media player should automatically download the codec.
if the file is an avi file encoded with ms mpeg-4 v3, then it won't play unless u have the hacked codecs which let you use the codec for avi files. this applies to both encoding and decoding, although some of the older microsoft codecs will still decode it. microsoft soon disabled this though.
i can't get the newer codecs to play them. the auto-download can't find an appropriate decompressor.
a long time ago i got the hacked m$ mpeg4 v3 codecs from http://www.digital-digest.com
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40
