I have captured some analog video and am making a DVD compliant mpeg file. I set the field order at A, and my video is jerky on my TV(plays fine on computer.
Is the correct feild order (B) for analog video in Video studio? I always use feild order (A) in Tmpenc, and the video is fine.
There is a option in video studio 7, that says "Frame Based" , does this setting analyze the video for me, and automatically chooses the best setting for me?
I use Field order "A" for capture/render/encode/burn withg out any problems. Make sure to use the same field order through out all your process starting with the capture. Change the frame base setting at capture to field order "A".
Also make sure that no where in any of your processes is it de-interlacing the video. It must stay interlaced if you are going to watch it on a non-progressive TV. -
I think field orders in Ulead products are inverted. If you choose field B it will work as field A and viceversa. Make a test and try Field Order B and you'll see.
Good Luck!
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 08:58 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 12:27 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 07:06 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 13:53 -
> Ulead VS11 Broken MPEG 2 Field order <
By Dark Alpha in forum EditingReplies: 8Last Post: 24th Jun 2008, 09:29
