Problem under mainconcept which does a perfect job of creating SVCD is that you can set the coder to split the files up into different segments.
The problem I had was that mainconcept would error when it did the first split.
I made some setting changes per the forum by uncheck reset clocks...but that did not work.
What did work was having the output file sent to a different Drive. I did not try a different folder yet....but having the D drive have the file and the C drive have the output....works.
