I got a 'puter with RDRAM. I know that if I add ram to it, it has to be the same type, RDRAM. But, If I take the RDRAM out of it, are the slots the same as the slots that take SDRAM normally?
No! You're screwed unless you keep buying RDRAM (or unless your mobo has separate slots for SDRAM). You can thank Rambus for that.
<font size=-1>[ This Message was edited by: Braindrain on 2001-07-08 13:58:07 ]</font> -
&^&%$%*%^$#%%#$#@@^%$&$#$%$&$%#&$$@ RDRAM!
They only made it because SDRAM is so cheap now!
