I have quite a few dvd-r's I've created on my Panasonic HS2 DVD-R Recorder. These are finalized DVD-Video discs that I have decided I want to make a backup. Some only have one item on it and some have several items on it and they range from home video to old classic tv shows from TV. My question, I have been trying to use Nero to copy it. It immediately says when it starts copying "Can only copy first data track to a DVD medium". Is there something I can change in options or should I look at another dvd copy program? Thank you.
You don't. Did you actually think that unit would be compatible with DVD R/RW format?
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
TSA not only copying but sharing your computer files
By deadrats in forum Off topicReplies: 1Last Post: 20th Jan 2010, 21:33 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07
