  1. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    BELOW-FROM TOSHIBA 's DESCRIPTION of this DVD-ROM reader...
    it seems to give your own burns differing treatment from STORE-BOUGHT fare.
    That is..the specs clearly state that it plays "-R" slower than "-ROM"
    WHY would a drive be so WRITEABLY CHALLENGED and why is my Sony so different?
    It reads -R and ROM up to the 16x- this drive is rated to do as well-
    on "ROM ONLY" (or can't I read?)
    ATAPI Half-Height
    DVD-ROM DRIVE 16X/48X
    SD-M1712
    Toshiba's new SD-M1712 16X DVD-ROM drive is the drive of choice for consumers that want the fastest access to hundreds of multimedia, gaming, reference and educational titles on DVD.
    2X DVD-RAM playback
    16X DVD-ROM playback
    4.8X DVD-R playback
    Does this in fact explain why some DVD-ROM drives WON'T do smooth FastFoward on home-burned stuff!?
    Is this drive only able to read at 4.8 times or copy at that slow speed?
    It means its faster to RE-RIP the whole disc rather than simply copy off a already ripped disc!
    INTERESTING
    Dec 2002
    Belgium
    With -R discs they mean DVD-Recordable media and with DVD-ROM they mean pressed DVD discs.
    Atm, a pressed DVD disc always has a higher reading speed (unless you have hacked firmware or smth,...)
    I found also the info a bit disturbing.
    Discs don't playback at 16x or 4.8x, playback is always at 1x
    The 16x indicates the "ripping" speed or the max data t ransfer (NOT playback).
    It's very logical that re-ripping the whole disc (a pressed DVD-ROM in your case) is faster than copying it from an already ripped disc (being a DVD-R).
    There's no big deal here actually.
    Sony DRU-500A v1.0d
    Toshiba SD-M1302 v1006
    Philips DVDR885P v1.7/8
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Now I'm upset..
    because any DVD I try to RIP MAXXES out at the DVD-R read rate
    NOT THE STATED READ SPEED FOR DVD-ROM (16x)
    That is as we've agreed, the specs state a different read rate for DVD-R
    than DVD-ROM
    So I see when I rip I'm gettin' the -R rate (max 4.8x) not the Rom rate
    Should I be upset?
