Any suggestions on how to convert DV that was captured/transfered from a digital camcorder to Divx? I tried VirtualDub, but it can't open the DV.
Couldn't you just save it as an avi or something from the program that you used to import the dv from? say if you used program x could you just import the dv and then save as something that vdub can read.
DV Avi are just a thin wrapper around the raw DV data and VirtualDub can't see them because it doesn't use DirectShow and therefore can't use the Microsoft Codec to open files of the dvsd type.
Your options are :
1. Open it using AviSynth and frameserve it to VirtualDub
2. Install the Mainconcept DV Codec and the files will play nicely.
3. Download the free Canopus DV codec and change the type of the AVI file from dvds to the canopus id (sorry I cant remember it right now)
I haven't tried option one a lot because I didnt want to use the MS codec anyway.
The only problem I've had with option 2 and 3 is that if I use the "DivX
Audio" codec, virtualdub stalls at frame 0 and I need to brutally terminate it. If I use the standard MP3 codec (that provides very low quality bitrates) everything works like a charm.
hope this helps
massimo
DivX conversion
By didikai in forum Video ConversionReplies: 2Last Post: 27th Nov 2011, 11:23 -
DivX/Xvid conversion
By joecass in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 15:23 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 02:22 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
...again .mkv to divx conversion...
By Conrad007 in forum Video ConversionReplies: 10Last Post: 6th Jun 2009, 15:37
