i can't see the scenes button on my 1st menu with dvd lab just my play button when i make it a motion menu but when i make it a still i see the both play and scenes button anybody know what i'm doing wrong or have the same problem
look in the DVD-Lab help under motion menu. There is a tutorial there that explains how to work with this very issue. Just follow the steps and you'll be right as the rain.
Motion menu's (the way you would logically think of them) are a little more complicated under DVD Lab.
What you need to do is this:
1. With your menu open, go to Menu->Export->As Overlay, and save the file somewhere. What this will give is a transparent background upon which your buttons are placed (No motion background or anything).
2. Now open up your favorite video editor, and put down the video you were planning to use as your motion menu background, and then take that .PNG file from step 1, and put it ontop. Render.
3. Take that rendered video and use THAT as the motion menu background. You'll still need to create buttons and regions, but everything will show all the time.
Good luck, ask for more help if you need. -
BEER,
PLEASE DON'T YELL AT ME BECAUSE YOU COULDN'T FIND WHAT YOU WERE LOOKING FOR!
This quick tutorial is in the DVD-Lab help as well as the website.
http://www.mediachance.com/dvdlab/tutorial/motionmenu.html
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 11:14 -
SW for cut / delete scenes
By Luoslav in forum EditingReplies: 2Last Post: 16th Oct 2010, 05:02 -
[DVDLAB] White afterimage when & after clicking button
By rmdeboer82 in forum Authoring (DVD)Replies: 3Last Post: 19th Aug 2008, 19:55 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 13:08 -
Best Scenes for a Demo DVD??
By mpalm887 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2007, 14:31
