I'm trying to cut out the mishaps in a family video that i captured using Cyber Links VCR II 3.0 from a VHS tape. The video is in MPEG-2 after i cut out the parts i don't want and then try to rejoin the clip the audio is always out of sync.
I have tried all the programs listed in the edit section for MPEG-2 and i end up with audio out of sync. DVD Lab keeps the audio in sync but it will only cut the end of a clip, i don't think it will cut a scene out in the middle.
Would it be better if i converted the clips to another format? All the clips i have is about 20min long i planed on joing them all together after i get them edited.
I am about ready to give up!!!![]()
problem solved!! I converted the MPEG-2 files to AVI uncompressed and edited them with VirtualDub and the audio was in sync!!
Best way/tools to sync audio to movement of lips?
By J-E-T-S in forum AudioReplies: 18Last Post: 8th Mar 2012, 18:06 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
Audio Sync trouble with Join
By RedDwarph in forum ffmpegX general discussionReplies: 8Last Post: 12th Apr 2009, 09:24 -
audio sync trouble on dvd to avi
By zookeeper525 in forum DVD RippingReplies: 5Last Post: 2nd Sep 2007, 11:23 -
need suggestions on tools to use for making DVD's
By leinan in forum Newbie / General discussionsReplies: 11Last Post: 8th Jun 2007, 15:22
