I need some help I'm try to encode my doby digital file to DTS sound,Does somebody know how to do that? or it's imposible.
surcode sells a dts encoder but I wouldn't recommend it if your source is dolby digital. your not going to gain quality by going from dd to dts. you'll actually lose quality because dts is still compressed and decompressing and recompressing with lossy formats always results in loss of quality no matter what. also any dts encoder is very expensive.
Originally Posted by ssi1975
Err...Donny just told you!
FYI, ssi1975, surcode software is also known as 'Minnetonka' software. The DTS software encoder they make costs $1,995Originally Posted by Donny661
http://www.minnetonkaaudio.com/
http://www.surcode.com (you can get a demo of the DTS encoder here)
I would second Donny661's remarks that it is pointless transcoding to DTS from AC3. It's like trying to make a Ferrari by disassembling a Lada and reassembling it using a Ferrari blueprint!
Arky ;o)
Which do you prefer - Dolby Digital or DTS?
By yoda313 in forum PollsReplies: 48Last Post: 17th Apr 2014, 23:49 -
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 00:32 -
Select Dolby Digital 5.1-ch, DTS 5.1-ch or both?
By coody in forum DVD RippingReplies: 6Last Post: 17th Feb 2008, 21:22 -
Does Divx contain the Dolby Digital and DTS sound.
By sam9s in forum DVD RippingReplies: 8Last Post: 11th May 2007, 16:37
