  1. So theres a spot thats giving me troubles on the stargate season 1 volume 3 dvd. I can get episodes 1,2,5 but I cannot get 3&4. They read for a awhile then give me this:
    Using a standalone DVD player I can play 3 & 4 but I do notice a 5 second pause at one point while playing episode 4 on the disc.
    PowerDVD cannot play Episode 4 at all
    Smartripper didnt work either
  2. Do you have a valid ASPI layer installed (not nero)
    Have you tried to clean the disc
    If power DVD won't play it I suspect that the disc is the problem (needs to be cleaned).
    Dec 2002
    Texas USA
    Bad discs.
    And FYI, the Stargate SG1 S1 discs had some major errors. I took two of mine back before I got a good set. Mine were normally a bad disc one from the set.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  4. I adjusted the # hardware and software read errors, and it appears that Im having Software Read Errors...
    I've done this before, and never had this problem.
