    Jan 2002
    When using IC7 and saving the files to hard drive to write later, after I delete the files I lose 1 gig of space on my hard drive. No files are left on the drive but I lose a gig of space. I have show hidden files so that is not the problem. By chance I defraged the drive and in the defrag the file does show up as A00013645.....pdi. I'm running Windows XP Home. In computer management the drive is shown as healthy (active). Does anyone have any ideas on this problem? I sure hate reformatting the drive every so often to get the space back and I really can't store anything else on the drive.
  2. have you got norton antivirus running?
    if so, i had the same problem and it was norton holding back.
    open norton and in options find where you can disable recycle bin protected files.
    thingimijig.
    Jan 2002
    I don't have Norton. I have McAfee so I'll check there and see if there is a setting I can change. I have no problem deleting the files I can see though.
  4. show the hidden files again and go to the c:\recycler dir, the pdi file should be there,just delete it...
    Jan 2002
    Could you tell me the complete path to recycler dir? I can't find it.
  6. you need to show hidden files or directorys and it is in the root directory of any disk i.e. c:\
    Jan 2002
    I have even the system files showing and the recylce bin does show up on my d drive but nothing is in it. I'm thinking this is some kind of temp file that's not getting erased or something. I'm at a loss.
