I have just started ripping DVD's, but I have already run into a problem. On one of the movies I ripped the last 2 VOB's only had background music, no voice tracks. The next movie, all the VOB's were fine except VOB_3 which was completly in french. I tried finding the english/voice files but came up empty. I also tried other rippers with exactly the same results. Is there a way to get a complete movie? I am really stuck, can anyone help?
thanks
What are you aiming for? Do you want to watch the vobs only or do you want to convert to whatever? Which steps did you do alreaddy?
I ripped the tracks to my harddrive and just to check that the VOB's ripped properly I watched each VOB seperately. I hadn't coverted yet as I figured why make a VCD with one section that was French. Does it convert with the proper audio? The problem I see is that it is always only 1 VOB that is the problem...If I switch the audio track as in the "directors cut posting" then all the other tracks will be wrong. Any ideas?
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=59907&forum=11
Did you decode the audio alreaddy? Vobs still contain all audio tracks after ripping. Extract the one or two audio tracks you want with an audio decoder (dvd2avi or vob2audio). -
I had something like this. I used (flask) & searched for the audio track that was 5.1 ac3 (dolby digital) also looked for 5.1 dts track as on most american disks, these tracks will be English only, not always, but worth the input to your sit.
Is it possible to decode individual VOB's with DVD2AVI or does it affect all of the other VOB's as well?(Sorry, I'm reeeeaaallly new at this)
Thanks for all your help.
<font size=-1>[ This Message was edited by: flyfishr on 2001-09-26 08:19:17 ]</font> -
First you load all vobs by selecting the first vob. Then delete all the vobs, that you don't want.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Unwanted Dolby Sound Mixed In With 2 Channel Stereo Tracks.
By travelagent73 in forum AudioReplies: 0Last Post: 18th Aug 2009, 11:49 -
No Audio on ripped DVD
By BigNoise in forum AudioReplies: 1Last Post: 17th Jul 2009, 21:57 -
updating ripped CDs on HDD - found out of order tracks
By Rudyard in forum ComputerReplies: 3Last Post: 20th Apr 2009, 23:59
